Displays how the switch builds an ARP table and learns MAC addresses for devices on a specific VLAN and associated member ports.
| vlan_name | Specifies the name of the VLAN. |
| vlan_list | Specifies the name of the VLAN list of IDs. |
N/A.
The switch displays the following ARP learning information:
The following sample output displays how the switch builds its ARP table for the VLAN learn:
# show ip-security arp learning vlan learn Port Learn-from ---------------------------------- 2:1 ARP 2:2 DHCP, poll 300 sec, retries 3 2:3 ARP 2:4 None 2:5 ARP 2:6 ARP 2:7 ARP 2:8 ARP
This command was first available in ExtremeXOS 11.6.
The vlan_list variable was added in ExtremeXOS 16.1.
